[postgis-devel] [Fwd: That jdbc bug on Rawhide]
Devrim GUNDUZ devrim at CommandPrompt.com
Mon Jan 1 13:29:15 PST 2007
Hello,
Here is the e-mail from Ruben. What he is talking about is the build
problem that I reported last week.
Regards, Devrim
-------- Forwarded Message --------
> From: Ruben Kerkhof <ruben at rubenkerkhof.com>
> To: devrim at commandprompt.com
> Subject: That jdbc bug on Rawhide
> Date: Thu, 28 Dec 2006 00:32:12 +0100
> Hi Devrim,
> I hope you're sleeping now, but in case you're bored tomorrow... I
> think I found the issue.
> Attached is a diff between the 2 postgres drivers. If you look
> carefully, you can see that the debug and info method are removed on
> Driver are removed in 8.2
> The postgis guys should probably call Logger.debug.
> Hope they can fix that.
> Good luck!
The PostgreSQL Company - Command Prompt, Inc. 1.503.667.4564
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, plPerlNG - http://www.commandprompt.com/
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070101/385e77f1/attachment.obj>
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070101/385e77f1/attachment.sig>
