[postgis-devel] joinsel Notices
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Jul 11 10:41:55 PDT 2007
On Wed, 2007-07-11 at 10:32 -0700, Paul Ramsey wrote:
> When I run a ST_DWithin() query, that does an expand() on each side of
> the pairing, I get the following notices:
> NOTICE:  LWGEOM_gist_joinsel called with arguments that are not column
> references
> references
> Any reason we can't demote those to a lower class of message? I think
> running a.geom && expand(b.geom) is a pretty common case.
> P
Hmmm that's strange - I already committed a fix for that here:
http://postgis.refractions.net/pipermail/postgis-commits/2007-June/000071.html.
I wonder if someone managed to overwrite with an older version of the
file from the SVN repository?
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
