[postgis-devel] Re: [postgis-users] installation problem
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Thu May 10 08:50:51 PDT 2007
On Thu, 2007-05-10 at 11:42 -0400, vamsee movva wrote:
> Hi Mark
> I commented all things which deals with templateGIS in GNUMake file.
> When i executed make i got the following errors
> lex.yy.c:4023: warning: `yyunput' defined but not used
> lwgeom_chip.c: In function `CHIP_in':
> lwgeom_chip.c:128: warning: int format, different type arg (arg 4)
> shpopen.c:176: warning: `rcsid' defined but not used
> dbfopen.c:206: warning: `rcsid' defined but not used
> make: *** No rule to make target `templategis', needed by `all'.
> Stop.
> Thanks
Hmmm I think that implies that you've missed this part from the diff:
-all: Makefile.config liblwgeom loaderdumper utils
+all: Makefile.config liblwgeom loaderdumper utils templategis
If you remove templategis from this line, does that help you at all?
Kind regards,
Mark.
