[postgis-devel] Moving towards a 1.2.2 release?
Michael Fuhr mike at fuhr.org
Thu May 17 05:32:15 PDT 2007
On Wed, May 16, 2007 at 04:06:52PM +0200, TECHER David wrote:
> I apply the patch you give us but without any succeed on
> - postgresql 8.3 dev from cvs
How recently did you update your 8.3 source tree?
> - postgis from svn patched with your patch
> - geos from svn OR geos-3.0.0-rc4
> and proj 4.5.0
> All my regression tests failed :(.
Hmmm...I get all tests passed with the latest PostGIS from SVN and
the latest PostgreSQL 8.3devel from CVS.
postgis=> select postgis_full_version();
 POSTGIS="1.2.2SVN" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS
(1 row)
postgis=> select version();
                                   version
 PostgreSQL 8.3devel on sparc-sun-solaris2.9, compiled by GCC gcc (GCC) 3.4.2
(1 row)
How exactly did you build, install, and test PostgreSQL and PostGIS?
Do you have multiple versions of either installed on the same system?
> The regression test for loader (shp2pgsql --> make -C regress)  implies
> that my server restarts! Why? I don't know
What errors appear in the PostgreSQL logs?  Did you get a core dump?
> For example for the tiny SQL instruction
> testgis=# select postgis_full_version();
> 2006" USE_STATS
> (1 ligne)
> testgis=# select 'LINESTRING(1 1, 2 2)'::GEOMETRY ~= 'LINESTRING(2 2, 1
> 1)'::GEOMETRY;
> NOTICE:  compute_serialized_box3d called on unknown type 0
> ERROR:  Unknown geometry type: 0
Works here:
postgis=> select 'LINESTRING(1 1,2 2)'::GEOMETRY ~= 'LINESTRING(2 2,1 1)'::GEOMETRY;
 ?column?
 f
(1 row)
Has anybody else tested the patch I sent against 8.3devel?
Michael Fuhr
