[postgis-devel] Re: [postgis-users] MSVC Patch #1
Charlie Savage
cfis at savagexi.com
Tue Oct 30 09:53:31 PDT 2007
> Yes indeed. My only other outstanding question was there was an
> liblwgeom.def exports file provided as part of the patch - can this not
> be generated automatically? Or does it require adding DLLEXPORT
> definitions to each function?
Two choices. First, add a DLLEXPORT definition. Second, provide a
prebuilt .def file.
Second choice is less invasive, so that's the way I went. I generated
it using gendef.pl provided by postgresql (see src\tools\msvc) and then
if I remember correctly hand-edited it a bit to remove stuff that
shouldn't be exported.
Auto-generating it would be nice - but how? Force users to have Active
Perl installed and reuse what postgresql provides. Write some batch
file? Just seemed easier to manually create it for now...
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20071030/cbb0738f/attachment.bin>
