[postgis-devel] Upgrading from 1.2.1 to 1.3.1
Charlie Savage cfis at savagexi.com
Tue Sep 4 09:22:45 PDT 2007
I've just upgraded a postgis 1.2.1 installation to 1.3.1.  To make sure
it worked correctly, I then did a diff between a fresh postgis 1.3.1
installation versus the upgraded one.
It looks like the upgrade script forgets to install a bunch of new
aggregates introduced in 1.2.2.  To get the two installations in syn, I
had to run the following sql on the upgraded database.
There also seems to have been a change to st_pointn which  now takes an
additional integer parameter.
Thanks,
Charlie
DROP FUNCTION postgis.st_pointn( geometry) CASCADE;
CREATE AGGREGATE ST_MemGeomUnion (
	basetype = geometry,
	sfunc = ST_union,
	stype = geometry
CREATE AGGREGATE ST_memcollect(
	sfunc = ST_collect,
	stype = geometry
CREATE AGGREGATE ST_Extent(
	sfunc = ST_combine_bbox,
	stype = box2d
CREATE AGGREGATE ST_Extent3d(
	stype = box3d
CREATE AGGREGATE ST_accum (
	sfunc = ST_geom_accum,
	stype = geometry[]
CREATE AGGREGATE ST_MakeLine (
	sfunc = geom_accum,
	stype = geometry[],
	finalfunc = ST_makeline_garray
CREATE AGGREGATE ST_Polygonize (
	stype = geometry[],
	finalfunc = ST_polygonize_garray
CREATE AGGREGATE ST_Union (
	stype = geometry[],
	finalfunc = ST_unite_garray
CREATE AGGREGATE ST_collect (
	stype = geometry[],
	finalfunc = ST_collect_garray
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070904/c62eb361/attachment.bin>
