[Fwd: [Fwd: Re: [postgis-devel] Re: Patch for PostGis Envelope Bug]]
Martin Davis
mbdavis at refractions.net
Fri Sep 21 16:25:49 PDT 2007
Charlie:
If the examples you give in the email below are actually what your
Envelope patch is doing, this is WRONG!
The envelope of non-horizontal/non-vertical linestrings will always be a
Polygon, not a Linestring. Only exactly horizontal or vertical
linestrings will have an envelope which is itself a LineString.
The way this should be implemented is to first compute the true extents
of the geometry. Then check the X &Y extents and return the appropriate
geometry constructed from the extent ordinates. The JTS code that does
this is:
public Geometry toGeometry(Envelope envelope)
// null envelope - return empty point geometry
if (envelope.isNull()) {
return createPoint((CoordinateSequence)null);
// point?
if (envelope.getMinX() == envelope.getMaxX() && envelope.getMinY()
== envelope.getMaxY()) {
return createPoint(new Coordinate(envelope.getMinX(),
envelope.getMinY()));
// vertical or horizontal line?
|| envelope.getMinY() == envelope.getMaxY()) {
return createLineString(new Coordinate[]{
new Coordinate(envelope.getMinX(), envelope.getMinY()),
new Coordinate(envelope.getMaxX(), envelope.getMaxY())
return createPolygon(createLinearRing(new Coordinate[]{
new Coordinate(envelope.getMaxX(), envelope.getMinY()),
new Coordinate(envelope.getMaxX(), envelope.getMaxY()),
new Coordinate(envelope.getMinX(), envelope.getMaxY()),
}), null);
-------- Original Message --------
Subject: [Fwd: Re: [postgis-devel] Re: Patch for PostGis Envelope Bug]
Date: Fri, 21 Sep 2007 16:11:51 -0700
To: martin Davis <mbdavis at refractions.net>
Subject: Re: [postgis-devel] Re: Patch for PostGis Envelope Bug
Date: Fri, 21 Sep 2007 15:05:54 -0600
Reply-To: PostGIS Development Discussion
<postgis-devel at postgis.refractions.net>
To: PostGIS Development Discussion <postgis-devel at postgis.refractions.net>
References: <46E09936.5030008 at savagexi.com>
<9245.1189132424 at sss.pgh.pa.us> <46E0E199.40302 at savagexi.com>
<46E13929.5090400 at vadose.org> <46E1739D.6030800 at savagexi.com>
<46E181A2.6050309 at refractions.net> <46E18A30.2000002 at savagexi.com>
<46E18B76.4000508 at refractions.net> <46E39FDC.3040005 at savagexi.com>
<46F09E3B.4080209 at savagexi.com>
<7F743A6F-517E-498F-A3D7-23793727D60A at refractions.net>
<46F43097.4010503 at savagexi.com>
And here is an example of its use:
select asText(envelope('POINT(10 10)'::geometry)),
asText(envelope('MULTIPOINT((10 10))'::geometry)),
asText(envelope('MULTIPOINT((10 10), (20 20))'::geometry)),
asText(envelope('LINESTRING(10 10, 50 50)'::geometry)),
asText(envelope('MULTILINESTRING((10 10, 50 50))'::geometry)),
asText(envelope('MULTILINESTRING((10 10, 50 50), (20 20, 70
70))'::geometry)),
asText(envelope('POLYGON((10 10, 50 50, 30 30, 20 20, 10
10))'::geometry))
"POINT(10 10)";
"POINT(10 10)";
"POLYGON((10 10,10 20,20 20,20 10,10 10))";
"LINESTRING(10 10,50 50)";
"POLYGON((10 10,10 70,70 70,70 10,10 10))";
"POLYGON((10 10,10 50,50 50,50 10,10 10))"
Charlie
Charlie Savage wrote:
> Hi Paul,
> Paul Ramsey wrote:
>> Applied to trunk. I don't see any way it can do harm.
> Here is patch to the patch (thus it applies against the trunk).
> It adds in support for returning a LineString if envelope is called on a
> line string (thus making this similar to the bbox to geom conversion
> routines).
> Also, it fixes a bug I introduced in the last version (not checking to
> see if the deserialized geom should be freed).
> Thanks,
> Charlie
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070921/8ff16e6c/attachment.txt>
