[postgis-devel] GeoJson export function
Courtin Olivier
olivier.courtin at camptocamp.com
Wed Apr 23 09:56:10 PDT 2008
GeoJson is a format we use widely between server and Web GIS
applications,
cf <http://wiki.geojson.org/GeoJSON_draft_version_6>
So it sounds like a good idea to have GeoJson native support
in PostGIS,
Attached to this post is a patch against current PostGIS SVN, with:
- ST_asGeoJson implementation
- units tests
- DocBook documentation entry
To play with it, after installation, generate a GeoJson element:
SELECT ST_AsGeoJson(the_geom) FROM your_table LIMIT 1;
and copy/paste the result in OpenLayers:
cf <http://openlayers.org/dev/examples/vector-formats.html>
Any reaction welcome,
HTH,
Olivier
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080423/6da1a2f5/attachment.obj>
