[postgis-devel] Problem with projection 31370 / 31300 (Belgian Lambert72)
Karel Maesen
karel at geovise.com
Mon Apr 28 13:04:52 PDT 2008
I recently did a project for a Belgian client. I ran into a problem
with the definitions for the Belgian Lambert72 CRS in the
spatial_ref_sys table (srid=31370 and 31300). Neither definition has
a correct proj4text CRS description string. In both cases the datum
transformation instruction is missing.
Lambert72 uses the BD72 datum and not WGS84. Due to the missing
datum transformation instruction, transforming Lambert72 to WGS84 in
Postgis results in geographic coordinates relative to the BD72 datum,
in stead of WGS84. This results in deviations in the order of 100-200
meter.
I determined that the following string needs to be added to the
proj4text:
+towgs84=-106.868628,52.297783,-103.723893,0.336570,-0.456955,1.842183,-
1
See the page at http://www.ngi.be/NL/NL4-4.shtm for reference. (Note
that the parameters indicated on this page are from ETRS89 to BD72.
They need to be inversed for the +towgs84 instruction. )
Could this be fixed in future versions?
Regards,
Karel Maesen
Geovise BVBA
