[postgis-devel] More Cascade Union Adventures
Obe, Regina robe.dnd at cityofboston.gov
Wed Aug 13 16:37:05 PDT 2008
Try this set.  - this has 2895 records
My timings are
---time 161,047 ms = SELECT 161047/1000.0/60 = 2.68 minutes
SELECT ST_CascadeUnion(the_geom)
from usstatebounds;
--time 121719 ms = SELECT 121719/1000.0/60 = 2.02 minutes
SELECT st_unitecascade_garray_sort(ARRAY(SELECT the_geom FROM usstatebounds));
In OJ - it gets to the last round and then fails with a Java out of Heap space error.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080813/b05d5aee/attachment.html>
Type: application/zip
Desc: usstatebounds.zip
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080813/b05d5aee/attachment.zip>
