[postgis-devel] RECHECK not supported in PsotgreSQL HEAD any more?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Aug 21 12:41:19 PDT 2008
Sorry to re-chew the RECHECK stuff, but am I right that our consistent
test is just checking that SRIDs are the same? I personally think we
should drop the test for performance reasons and transfer the moral
hazard to the users: if they want to try do index runs across
reference systems, go for it. Besides, if they happen to use *any*
spatial functions in their SQL, they'll get stopped at the point they
enter the function by an SRID test anyways, so the risk of
"surprisingly wrong" results is very low.
P.
On Thu, Aug 21, 2008 at 4:06 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Mark Cave-Ayland wrote:
>> Okay. Assuming that this is the only problem with PostGIS against
>> PostgreSQL CVS, a fix should be relatively straightforward. I'll see what I
>> can do.
> All done. Jørgen, please can you do an SVN update at your end and re-test?
> Many thanks,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
