[postgis-devel] Updated SVN documentation
Obe, Regina
robe.dnd at cityofboston.gov
Fri Aug 22 09:31:02 PDT 2008
Mark,
Rather than reverting, I was thinking of updating and removing the
stuff we don't agree with would be better. Note I haven't touched the
1.3 which I think is what most people will be looking at anyway.
The original instructions as they were - I couldn't even follow so they
didn't seem terribly useful and if they aren't useful to me as a
marginally competent PostGIS user (less competent on Linux), I imagine
others would have trouble following them.
I can take the sudo instructions out. I was testing on OpenSuse and the
below worked fine and for many installs - I figured people would not
necessarily be logged in as root.
sudo/su - seems like we should at the very least make a note about that.
Yes the autogen.sh stuff you are right, I'll remove and would only
confuse users.
Now about Hard-coded tarball URLS with version numbers - I thought about
this a bit and there are a couple of reasons why I intentionally
hard-coded
1) The way different linux systems package stuff is different - so
certainly can't get into details there without going into some diatribe.
Frankly I don't really trust the versions packaged in - e.g. some have
old geos and so forth and left up to the discretion of what the platform
thinks is stable. Also I wouldn't want people left to there own devices
mindlessly installing the geos 3.1 which is not stable yet.
2) If you are going to be using your packaging system to install geos,
proj and other stuff - wouldn't you be doing the same for PostGIS? so
you wouldn't even be following these instructions anyway.
Thanks,
Regina
i) The section at the top which describes versions of things being used
- gcc, pg_config and geos_config are now automatically detected by
configure (if alternative pg_config/geos_configs are specified, the
complete path to the version being used is output to the console)
- "ldconfig -v | grep iconv" doesn't help on systems like mine where
iconv is built into libc
- flex & bison are only needed if you intend to alter the lexer/parser
since we commit the generated versions into SVN, so normal users do not
need to worry about this
ii) Hard-coded tarball URLs with version numbers
- The links to the PROJ and GEOS libraries are now hard-coded, with
version numbers. What would happen if the download URLs changed? Plus if
people were to download fixed versions by copying and pasting from the
instructions, they could miss updates for bugs as the packaged
documentation will be out of date
- Having the tarballs listed like this will make people think that they
need to compile extra libraries by hand - surely we should be
encouraging people to use their native package system first, and only
requiring compilation if these versions are too old?
iii) configure is hidden
- The configure step doesn't particularly clear anymore, at least not to
my eyes
iv) autogen.sh
- There are references to autogen.sh in the instructions. This is only
required for building from SVN trunk, since configure is generated as
part of the tarball release. And I think autogen.sh is removed from the
release tarballs too.
v) sudo
- I don't think the use of sudo makes things any clearer for beginners
since it isn't installed on all systems by default. For example, it's
not on any of my Fedora default virtual installs, or my normal desktop
workstation (I wonder if these instructions were written for Ubuntu?). I
think it would end up confusing people even more, rather than helping
them...
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
