[postgis-devel] Updated SVN documentation
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 22 13:17:27 PDT 2008
I think we should include basic installation instructions for Proj4
and GEOS as part of the PostGIS doco.  They should include the
relevant URL to get the source, and the simplest step-by-step: "as
root, ./configure; make; make install".  They should also include the
fix for the standard Linux "gotcha", which is not having
/usr/local/lib in /etc/ld.so.conf and running /sbin/ldconfig.
P.
On Fri, Aug 22, 2008 at 12:09 PM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> In terms of installation for PROJ/GEOS, it would make more sense to refer
> people to the relevant installation pages for each project rather than try
> and encapsulate everything within the one page; for me it just makes
> things more cluttered. If you look around at other projects such as
> PostgreSQL, Apache etc. then you can see a similar pattern within the
> documentation - give the basic installation instructions, and list other
> dependencies separately in a requirements section.
