[postgis-devel] CLUSTER in 8.3
Paul Ramsey
pramsey at cleverelephant.ca
Thu Dec 4 12:37:44 PST 2008
Maybe I'm doing something wrong... here's a log of how I exercised this:
pramsey=# create table ttt as select * from counties;
SELECT
pramsey=# create index ttt_gix on ttt using gist(the_geom);
CREATE INDEX
pramsey=# clusture
pramsey=# select count(*) from ttt;
count
3141
(1 row)
pramsey=# cluster ttt using ttt_gix;
CLUSTER
count
0
(1 row)
pramsey=# select version();
version
PostgreSQL 8.3.5 on i386-apple-darwin9.5.0, compiled by GCC
i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
(1 row)
pramsey=# select postgis_full_version();
POSTGIS="1.3.4SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
(1 row)
pramsey=#
On Wed, Dec 3, 2008 at 8:43 AM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Is seems fine (for Points anyway) on my 8.3.3 install running on an old FC3
> box.
> Did you run out of disk space? Did the transaction get half way through and
> was forced to stop?
> -- Kevin
> Paul Ramsey wrote:
>> Is it just me, or has clustering on spatial indexes stopped working in
>> 8.3? First, the syntax of CLUSTER has been changed, from "CLUSTER
>> [index] ON [table]" to "CLUSTER [table] USING [index]". Second, when I
>> run the new syntax using a gist index as the target, the index
>> disappears and all row count drops to zero!
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
