[postgis-devel] CLUSTER in 8.3
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Dec 4 14:30:17 PST 2008
On Thu, 2008-12-04 at 13:51 -0800, Kevin Neufeld wrote:
> Wow, that's bad. I just updated to PostgreSQL 8.3.5 from 8.3.3 and I now get the same thing.
> test=# create temp table tmp as select st_makepoint(random(), random()) as the_geom from generate_series(1, 10000);
> SELECT
> test=# create index tmp_geom_idx on tmp using gist (the_geom);
> CREATE INDEX
> test=# analyze tmp;
> ANALYZE
> test=# select count(*) from tmp;
> count
> 10000
> (1 row)
> test=# cluster tmp using tmp_geom_idx;
> CLUSTER
> test=# analyze tmp;
> ANALYZE
> count
> 0
> (1 row)
> test=# select version();
> version
> PostgreSQL 8.3.5 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
> (1 row)
> test=# select postgis_full_version();
> POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.4.9, 29 Oct 2004" (procs from 1.4 USE_GEOS=1 USE_PROJ=1
> USE_STATS=1 need upgrade)
> (1 row)
> -- Kevin
Yuck. If you can definitely confirm that this works on 8.3.3 but not
8.3.5 then it's probably work a post on -hackers :(
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
