[postgis-devel] CLUSTER in 8.3
Obe, Regina
robe.dnd at cityofboston.gov
Thu Dec 4 20:44:25 PST 2008
I tried your test on my all_counties table and it worked fine. But I was doing it from pgadmin III. and I have left out that clusture thing you were doing. What does that do? :)
create table ttt as select * from all_counties;
create index ttt_gix on ttt using gist(the_geom);
cluster ttt using ttt_gix;
select count(*) from all_counties;
-- gives me 3141 records --
I guess we must have similar county tables since we have the same record count.
My projection is in 3395.
running
"PostgreSQL 8.3.5 on i686-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.1.2 20071124 (Red Hat 4.1.2-42)"
"POSTGIS="1.3.4" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
Hope that helps,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Thu 12/4/2008 3:37 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] CLUSTER in 8.3
Maybe I'm doing something wrong... here's a log of how I exercised this:
pramsey=# create table ttt as select * from counties;
SELECT
pramsey=# create index ttt_gix on ttt using gist(the_geom);
CREATE INDEX
pramsey=# clusture
pramsey=# select count(*) from ttt;
count
3141
(1 row)
pramsey=# cluster ttt using ttt_gix;
CLUSTER
count
0
(1 row)
pramsey=# select version();
version
PostgreSQL 8.3.5 on i386-apple-darwin9.5.0, compiled by GCC
i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
(1 row)
pramsey=# select postgis_full_version();
POSTGIS="1.3.4SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
(1 row)
pramsey=#
On Wed, Dec 3, 2008 at 8:43 AM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Is seems fine (for Points anyway) on my 8.3.3 install running on an old FC3
> box.
> Did you run out of disk space? Did the transaction get half way through and
> was forced to stop?
> -- Kevin
> Paul Ramsey wrote:
>> Is it just me, or has clustering on spatial indexes stopped working in
>> 8.3? First, the syntax of CLUSTER has been changed, from "CLUSTER
>> [index] ON [table]" to "CLUSTER [table] USING [index]". Second, when I
>> run the new syntax using a gist index as the target, the index
>> disappears and all row count drops to zero!
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081204/a9dc7de4/attachment.html>
