[postgis-devel] CLUSTER in 8.3 on GIST indexes break
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Dec 5 05:05:43 PST 2008
Hi Kevin,
Yeah I see exactly the same problem on 8.3.5 too, although it seems
random - what seems to happen is that sometimes the contents of the
temporary table disappears. I've attached a test script which causes the
error *some* of the time, although it tends to occur more often just
after the server has been restarted.
I've been invoking the attached script against a PostgreSQL
8.3.5/PostGIS 1.3.4 installation, and when the bug hits I see the
following psql output against a freshly restarted server:
postgis13=# \i /tmp/postgis-strange.sql
SELECT
CREATE INDEX
ANALYZE
  count
  10000
(1 row)
CLUSTER
ANALYZE
  count
  10000
(1 row)
psql:/tmp/postgis-strange.sql:2: ERROR:  relation "tmp" already exists
psql:/tmp/postgis-strange.sql:3: ERROR:  relation "tmp_geom_idx" already
exists
ANALYZE
  count
  10000
(1 row)
CLUSTER
ANALYZE
  count
      0
(1 row)
exists
ANALYZE
  count
      0
(1 row)
CLUSTER
ANALYZE
  count
      0
(1 row)
So in other words, the contents of the temporary table has just
disappeared :(
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081205/83e04cf5/attachment.ksh>
