[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com
Fri Dec 5 05:53:26 PST 2008
Updates:
Status: Testing
Comment #9 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
I haven't tested this in ArcGIS yet, but will after I reinstall on my
computer. I
did check out does output the .prj in a number of permutations of options.
Accidentally confirmed that if you have a bogus record in your
geometry_columns table
that references a table with same name as table you are outputting and you
don't
specify a schema, a projection will not be output and prj creation will
return with
an error. This I don't consider to be a real issue.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
