[postgis-devel] Issue 14 in postgis: Add regress_ogc_prep back into regress tests.
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 9 05:26:19 PST 2008
Updates:
	Status: Fixed
Comment #3 on issue 14 by robe.... at cityofboston.gov: Add regress_ogc_prep
http://code.google.com/p/postgis/issues/detail?id=14
This is marked as Verified when Verified was higher than fixed.  Is there
any way to
do a macro update of all Verified to fixed?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
