[postgis-devel] Issue 82 in postgis: Bug in bug tracker
codesite-noreply at google.com
Tue Dec 9 05:34:23 PST 2008
Status: Accepted
Owner: robe.... at cityofboston.gov
New issue 82 by robe.... at cityofboston.gov: Bug in bug tracker
http://code.google.com/p/postgis/issues/detail?id=82
What steps will reproduce the problem?
1. Hmm now that we all agree on Fixed as the new verified or old verified
as new fixed, search doesn't work right
2. Try to select "Issues to Verify" and you see all our fixed. Can we fix
this so that testing gets treated as Old fixed and search says "Issues to
Test"
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
