[postgis-devel] Re: [postgis-users] Changed bahaviour of PostGISconfuses MapServer
Kevin Neufeld
kneufeld at refractions.net
Sat Dec 13 21:59:33 PST 2008
Sounds ok to me. BTW, I added a brief note to the downloads page
indicating why 1.3.4 is no longer listed ... just so people don't get
confused and wonder what happened.
-- Kevin
Paul Ramsey wrote:
> Fair enough. Then I would like to change the PostGIS downloads page to
> reference 1.3.3 in the interim... P.
> On Sat, Dec 13, 2008 at 11:46 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>> -1
>> Well I mean not ASAP. Lets wait till at least Tuesday. I agree it is a
>> far reaching bug that I suspect affects many functions. Anything that needs
>> to extract a multi into individual linestrings will be affected.
>> Then again I'm not convinced that many people have deployed into production
>> and this to me would affect people who are unable to compile for themselves
>> more than anyone else (e.g lots of windows users who have deployed) so we
>> have to wait for Mark's +1 anyway.
>> Besides I want to get the torture script further along to brute force test
>> to make sure no other surprises. So far the torture script
>> tests all the functions that deal with one geometry, or 2 geometry or no
>> args, but have yet to test for things that take other arguments (like all
>> the Affine and so forth).
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
>> Sent: Sat 12/13/2008 12:13 PM
>> To: PostGIS Users Discussion; PostGIS Development Discussion
>> Subject: [postgis-devel] Re: [postgis-users] Changed bahaviour of
>> Yes, Peter, I think it should call for a quick 1.3.5. Mapserver users
>> are a huge contingent of PostGIS users, and anyone with a LINE layer
>> now has a crasher. 1.3.5 should come off the line ASAP. There's always
>> more version numbers, IMO.
>> Can we have a quick vote on 1.3.5 release-from-branch, no-waities?
>> +1
>> P.
>> On Sat, Dec 13, 2008 at 1:25 AM, Peter Hopfgartner
>> <peter.hopfgartner at r3-gis.com> wrote:
>>> Mark Cave-Ayland wrote:
>>>> Peter Hopfgartner wrote:
>>>>> Dear MLs,
>>>>> sorry for cross-posting to both, PostGIS and MS, but seems to rtouch
>>>>> both.
>>>>> I've tried to install PostGIS 1.3.4 on a CentOS 5 server with MapServer
>>>>> 5.2.1 and PostgreSQL 8.2.11.
>>>>> the command:
>>>>> shp2img -l prova -e 1587541 5116731 1591730 5120008 -m prova.map >
>>>>> ../../public/technet/test-<pgis-version>.png
>>>>> with 1.3.3 gave the result shown in figure test-postgis-1.3.3-4.png (a
>>>>> simple line layer)
>>>>> Upgrading to 1.3.4 the picture became as in test-postgis-1.3.4-1.png, an
>>>>> empty picture.
>>>>> The relevant mapfile fragment is Mapfile.frag.txt, the SQL table
>>>>> definition is e405.sql, all objects are MULTILINESTRINGs [SELECT
>>>>> DISTINCT
>>>>> geometrytype(the_geom) FROM public.e405 results in MULTILINESTRING], the
>>>>> geometry column is registered as MULTILINESTRING in geometry_columns.
>>>>> Running the MapServer query:
>>>>> SELECT
>>>>> asbinary(force_collection(force_2d(the_geom)),'NDR'),common_uid::text
>>>>> from
>>>>> public.e405 WHERE (tiplinapp is not null) and (the_geom && setSRID(
>>>>> 'BOX3D(1587541 5116702.44897959,1591730
>>>>> 5120036.55102041)'::BOX3D,find_srid('','public.e405','the_geom') ))
>>>>> changed for better result readability into:
>>>>> SELECT AsEWKT(force_collection(force_2d(the_geom))),common_uid::text
>>>>> from
>>>>> by hand gives slightly different results, as shown in the attached
>>>>> files.
>>>>> To make a long story short, 1.3.4 seems to better preserve the
>>>>> MULTILINESTRING, but this seems to confuse MapServer.
>>>>> Regards,
>>>>> Peter
>>>> Hi Peter,
>>>> This is likely the known issue with MULTILINESTRINGs in 1.3.4 causing
>>>> segfaults :( The patch you need is very simple and can be found here:
>>>> http://postgis.refractions.net/pipermail/postgis-commits/2008-December/000866.html
>>>> if you can't wait for a 1.3.5 release. Please let us know whether this
>>>> resolves the problem for you.
>>>> HTH,
>>>> Mark.
>>> Should this issue call for a quick 1.3.5 release? If I understood this
>>> issue
>>> well, everybody rendering PostGIS data stored as a MULTILINE geometry will
>>> have this very same problem, at least with MapServer. I would guess that
>>> this is quite a big share of PostGIS users that will be hit by this issue.
>>> Regards,
>>> Peter
>>> Dott. Peter Hopfgartner
>>> R3 GIS Srl - GmbH
>>> Via Johann Kravogl-Str. 2
>>> I-39012 Meran/Merano (BZ)
>>> Email: peter.hopfgartner at r3-gis.com
>>> Tel. : +39 0473 494949
>>> Fax : +39 0473 069902
>>> www : http://www.r3-gis.com
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you received
>> this in error, please contact the sender and delete the material from any
>> computer.
>> Help make the earth a greener place. If at all possible resist printing this
>> email and join us in saving paper.
