[postgis-devel] Issue 83 in postgis: ST_Multi on curved polygon gives ERROR: Unknown geometry type: 0
codesite-noreply at google.com
Sun Dec 14 07:04:31 PST 2008
Status: Accepted
Owner: robe.... at cityofboston.gov
New issue 83 by robe.... at cityofboston.gov: ST_Multi on curved polygon gives
http://code.google.com/p/postgis/issues/detail?id=83
What steps will reproduce the problem?
1. SELECT
ST_AsText(ST_Multi(ST_LineToCurve(ST_Buffer(ST_MakePoint(i,j),2))))
FROM generate_series(1,2) AS i CROSS JOIN generate_series(3,4) AS j
What is the expected output?
On 1.3.3 install it gives
"CURVEPOLYGON(CIRCULARSTRING(3 3,2.4142135623731 1.58578643762691,1
1,-0.414213562373101 4.41421356237309,3 3))"
"CURVEPOLYGON(CIRCULARSTRING(3 4,2.4142135623731 2.58578643762691,1
2,-0.414213562373101 5.41421356237309,3 4))"
"CURVEPOLYGON(CIRCULARSTRING(4 3,3.4142135623731 1.58578643762691,2
1,0.585786437626899 4.41421356237309,4 3))"
"CURVEPOLYGON(CIRCULARSTRING(4 4,3.4142135623731 2.58578643762691,2
2,0.585786437626899 5.41421356237309,4 4))"
What do you see instead?
This was uncovered during torture testing on 1.3.5SVN. Haven't verified
the issue exists in 1.4 but didn't give error in 1.3.3.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
