[postgis-devel] Issue 84 in postgis: Typo in Boundary error message
codesite-noreply at google.com
Sun Dec 14 07:36:36 PST 2008
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Type-Defect Priority-Low
New issue 84 by robe.... at cityofboston.gov: Typo in Boundary error message
http://code.google.com/p/postgis/issues/detail?id=84
What steps will reproduce the problem?
1. SELECT ST_AsEWKT(ST_Boundary(the_geom)),
ST_AsEWKT(ST_Boundary(ST_Multi(the_geom)))
FROM ((SELECT
ST_Collect(ST_Collect(ST_SetSRID(ST_MakePoint(i,j,m),4326),ST_SetSRID(ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_MakePoint(i+m,j,m),ST_MakePoint(j+m,i-m,m)),ST_MakePoint(i,j,m)),MakePointM(i+m,j,m))),4326)))
As the_geom
FROM generate_series(-10,50,20) As i
CROSS JOIN generate_series(50,70, 20) As j
CROSS JOIN generate_series(1,2) As m
GROUP BY m)) As foo;
What is the expected output?
ERROR: GEOS boundary() threw an error!
What do you see instead?
ERROR: GEOS bounary() threw an error!
Uncovered during testing 1.3.5SVN, but exists in 1.3.3 and admittedly is a
petty complaint.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
