[postgis-devel] Issue 83 in postgis: ST_Multi on curved polygon gives ERROR: Unknown geometry type: 0
codesite-noreply at google.com codesite-noreply at google.com
Mon Dec 15 02:43:13 PST 2008
Updates:
	Status: Testing
Comment #3 on issue 83 by mark.cav... at siriusit.co.uk: ST_Multi on curved
http://code.google.com/p/postgis/issues/detail?id=83
I see what happened here: when I introduced the new
lwgeom_contains_subgeoms()
function, I misunderstood what the logic was doing in LWGEOM_force_multi.
The mistake
I made was assuming that all non-collection types can be converted to
MULTI; whereas
in fact the only types that can be converted to MULTI are the standard
POINT,
LINESTRING and POLYGON since these are the only MULTI types that exist!
I've committed a patch to clarify the logic and your example above now
works (i.e. it
maintains the same behaviour in 1.3.3). I guess if people think that this
behaviour
is wrong we could discuss it further, but at the moment it's not
particularly clear
exactly what it should be.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
