[postgis-devel] CUnit
    Mark Leslie
    mrk.leslie at gmail.com
    Tue Dec 16 15:28:22 PST 2008
Agreed.  I haven't worked with cunit much at all, so I can't speak to
the technology, but unit tests are worth their weight in blood, sweat
and beers.  It would be a huge effort to write tests for all existing
functionality, but I think it would be reasonable to require new
functionality to have decent test coverage.  Then we can add tests for
existing functionality as we fix it.
Hard-coding the path seems like an immediate problem.  Just grabbing
cunit with apt-get I see that it installed into /usr as I would expect.
  If this is definable in configure it won't be a problem.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
Kevin Neufeld wrote:
> I think having the ability to perform unit tests is, as you say,
> invaluable.  As the code base grows, it becomes harder to manage /
> easier to break some portion of the codebase that depends on other
> portions.  If we can swing it, I vote to introduce the harness.
> We could add a "make code-check" or something to the main Makefile.
> -- Kevin
> Paul Ramsey wrote:
>> FYI, I've committed in the early bits of code on my line crossing
>> project. Most interesting to the development community is the contents
>> of 'cunit', which is a cunit test harness directly working on
>> liblwgeom. It was really invaluable for testing the code, I must say.
>> Good work Mark on breaking out liblwgeom, it has all worked as
>> advertised so far.
>> I'm interested in thoughts on how we should handle cunit tests, or if
>> we should even have them at all. Right now there is a hardcode
>> dependency on have cunit installed in /usr/local, but obviously it is
>> still early days.
>> Paul
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
