[postgis-devel] Testing ST_LineMerge issue
Obe, Regina
robe.dnd at cityofboston.gov
Wed Dec 17 10:25:47 PST 2008
I haven't tried on 1.3.5 or 1.4, but on 1.3.3 it does.
SELECT ST_GeomFromText(ST_AsText(ST_MakeLine(ST_Point(1,1), ST_Point(1,1))))
So I guess at least we are consistent.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 12/17/2008 1:06 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Testing ST_LineMerge issue
Our parser doesn't let that be created (does it?) so why should a
constructor? I think as long as our policy is consistent, we're doing
OK.
P.
On Wed, Dec 17, 2008 at 7:33 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> I was thinking about this failed test more and even though I had
> dismissed it as something only a Monkey would do that is not urgent.
> It has occurred to me that I may run into this issue with Monkey users
> and I may have already that may be a culprit in my geoserver random
> disconnects.
> At least one of the projects I'm working on I have run into users
> creating invalid geometries. Since they put in a lot of effort making
> these monsters, we decided to just check on some schedule to make sure
> the new geometries being created are valid.
> The monster I am talking about is this innocent one that I took out of
> the torture script because well you can't torture a dead server.
> In its simplest form it looks like this.
> SELECT ST_LineMerge(ST_MakeLine(ST_Point(1,1), ST_Point(1,1)));
> Now there are 2 issues here.
> 1) GEOS ST_LineMerge is obviously not smart enough to realize that
> linemerging something like that is silly.
> 2) ST_MakeLine lets you get away with creating this monstrosity. Which
> hmm I suppose there are reasons why someone may want to, but perhaps we
> shouldn't go there.
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081217/d8d3db4d/attachment.html>
