[postgis-devel] Issue 88 in postgis: pgsql2shp crashes on Vista
codesite-noreply at google.com
Mon Dec 22 15:42:18 PST 2008
Updates:
Status: Fixed
Comment #2 on issue 88 by robe.... at cityofboston.gov: pgsql2shp crashes on
Vista
http://code.google.com/p/postgis/issues/detail?id=88
Tested this on Vista and works fine now. Confirmed the old works if using
binary
(-b) switch. I'm closing this out.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
