[postgis-devel] AsSVG patch
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Thu Feb 7 23:29:59 PST 2008
Dear postgis developers,
Find attached a patch that improves the svg output:
* Support of GeometryCollection geometries
* proper closing of the SVG path geometries using the SVG "z|Z" command (in
case of POLYGON|MULTIPOLYGON elements)
* introduction of additional white-spaces in some cases for easier parsing
* removal of unnecessary minus signs infront of "0" coordinates
The patch has been tested by the SVG experts Andreas Neumann,  Klaus Förster
and Bruce Rindahl. It would be great if the patch could be integrated into
postgis svn. Please review the code carefully, as I'm a newbie in postgis
server programming.
The documentation of ST_AsSVG could be changed the following way:
ST_AsSVG(geometry, [rel], [precision])
Return the geometry as an SVG path data. Use 1 as second argument to have the
path data implemented in terms of relative moves, the default (or 0) uses
absolute moves. Third argument may be used to reduce the maximum number of
decimal digits used in output (defaults to 15). Point geometries will be
rendered as cx/cy when 'rel' arg is 0, x/y when 'rel' is 1. Multipoint
geometries are delimited by commas (","), GeometryCollection geometries are
delimited by semicolons (";").
Best regards,
Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080208/b5c2daa6/attachment.diff>
