[postgis-devel] Updates to GEOS & POSTGIS
Ben Jubb
benjubb at refractions.net
Fri Jan 18 09:26:52 PST 2008
Mark Cave-Ayland wrote:
> On Thu, 2008-01-17 at 17:07 -0800, Ben Jubb wrote:
>> Hi all,
>> I've checked in some changes to GEOS & PostGIS, All changes are in the
>> pursuit of getting prepared geometry (from JTS 1.9) into PostGIS.
>> First in GEOS:
>> exposed the prepared geometry objects in the CAPI, bumping the version
>> of CAPI to 1.5.0.
>> fixed a few small problems in the GEOS code.
>> Then in PostGIS:
>> Added new functions to lwgeom_geos_c.c to support prepared geometry
>> predicates.
>> bool containsPrepared( geom, geom)
>> bool containsProperlyPrepared( geom, geom)
>> bool coversPrepared( geom, geom)
>> bool intersectsPrepared( geom, geom)
>> These functions require a caching mechanism to retain some state between
>> calls. All of these functions work the same way. The first argument is
>> checked every time to see if its been seen before. If so, the geometry
>> argument is prepared and cached, if it hasn't been already. Subsequent
>> calls to these predicate functions with the same first argument will use
>> the cached prepared geometry to do the test, potentially saving a lot of
>> time.
>> These functions only show improvements when the first (or both)
>> argument(s) is(are) fairly large objects (>1000 points or so). The
>> caching overhead wipes out any gains with smaller objects.
>> The functions are exposed to PostgreSQL via these wrappers:
>> ST_ContainsPrepared( geometry, geometry )
>> ST_ContainsProperlyPrepared( geometry, geometry )
>> ST_CoversPrepared( geometry, geometry )
>> ST_IntersectsPrepared( geometry, geometry )
>> as well, this function was added, for orthogonality:
>> ST_ContainsProperly( geometry, geometry )
>> Hopefully somebody has a big polygon and thousands of geometries to test
>> against that polygon. This should make things happen a bit quicker.
>> Hopefully alot quicker.
>> cheers
>> b
> Hi Ben,
> An interesting commit - it will be fascinating to see exactly how much
> this will speed up these types of operations.
> I had a quick look at your commit out of curiosity, and noted the
> following things that might be worth looking at:
> - Use of C++ (//) comments
> I seem to remember that strk had to go through and change all //
> comments to /*..*/ comments to get PostGIS to compile on some of the
> more strict C compiler platforms - it may be worth changing these over.
> - Missing initGEOS() call
> Unlike the existing PostGIS functions that use GEOS, there is no
> initGEOS call within the function.
> - Size calculation
> I noticed that in your code, you use the following to find out the size
> of the geometry:
> arg1_length = toast_raw_datum_size(PG_GETARG_DATUM(0)) - VARHDRSZ;
> I think that since the Datum is detoasted into geom1, you should be able to use
> the following a bit lower down instead (which should be more future-proof):
> arg1_length = VARSIZE(geom1) - VARHDRSZ;
> HTH,
> Mark.
Mark,
thanks for the comments,
- I'll change the comment style..
- added the initGEOS() calls, oops..
- the size calculation: ill try your suggestion for getting arg1_length.
The method I use to check the identity of the first geometry argument is
troublesome to me. Right now, I do a memcmp() on the de-toasted
argument, and the previously stored argument in the cache. This seems
like alot of work to me, but I having trouble coming up with a better
way. One way that occured to me is to store the toasted data in the
cache instead, and do the comparison on the compressed data instead.
But is there a future-proof way to get the uncompressed data for the
datum? Looks like I need to rip out the guts of toast_fetch_datum() to
do it.
cheers
b
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080118/6d9be61e/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080118/6d9be61e/attachment.vcf>
