[postgis-devel] Updates to GEOS & POSTGIS
Tom Lane tgl at sss.pgh.pa.us
Fri Jan 18 20:09:45 PST 2008
Ben Jubb <benjubb at refractions.net> writes:
> The method I use to check the identity of the first geometry argument is
> troublesome to me.  Right now, I do a memcmp() on the de-toasted
> argument, and the previously stored argument in the cache.  This seems
> like alot of work to me, but I having trouble coming up with a better
> way.  One way that occured to me is to store the toasted data in the
> cache instead, and do the comparison on the compressed data instead.
> But is there a future-proof way to get the uncompressed data for the
> datum?  Looks like I need to rip out the guts of toast_fetch_datum() to
> do it.
I would *strongly* recommend not getting too familiar with the guts of
the toasting mechanism; that's one of the best ways to de-future-proof
your code that I can think of :-(
I don't really see anything much wrong with the memcmp idea, although
here are a few thoughts:
* memcmp is cheap as long as it hits a diff before proceeding real far.
You might want to organize the field order with malice aforethought
so that likely-to-be-different fields appear earlier.
* Be sure there are no uninitialized bits hiding anywhere in the struct,
like in padding bytes between fields.  If you make a practice of zeroing
the struct (eg with palloc0) before you fill the fields, this should be
okay.
* If you are dealing with float data then there's a small problem: zero
and minus zero are equal according to the IEEE spec, but not according
to memcmp.  I think you can probably ignore this for the case of
deciding whether a cache entry is still valid, since a phony "not equal"
indication is at worst a performance hit not a correctness problem.
But it's something to keep at the back of your head.
			regards, tom lane
