[postgis-devel] Removing geometry parsing checks for data loading
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 4 08:36:03 PDT 2008
My experience has been that in the case of non-closed polygons, the
final duplicate vertex is often "implied". So one way to "have our
cake and eat it too" would be to add the duplicate vertex at load
time. If that sounds overly harsh, than probably the things you are
loading aren't actually polygons, so you should go back and call them
linestrings and start again.
P.
On Fri, Jul 4, 2008 at 2:23 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> David Fuhry wrote:
>> $ shp2pgsql -D poly_1.shp poly_1 | psql
>> ERROR: geometry contains non-closed rings
>> CONTEXT: COPY poly_1, line 389, column the_geom:
>> "01060000000100000001030000000100000007000000F06044A5C0B53E41086D2D657C8C23413D5FFD71BFB53E4191925462..."
>> ROLLBACK
>> What's the best way to drop these geometry-parsing checks (from
>> lwgparse.c, I assume)? Is commenting out the if (...) error(...); lines
>> in popc() sufficient and safe?
>> Obviously as part of my import routine, I check that the geometries are
>> isvalid() later. For my uses, geometry errors are best resolved with
>> custom logic /after/ the data is in the db.
>> If Mark and others have serious concerns about people naively using
>> non-isvalid() geometries, then I suggest a configurable parameter to
>> shp2pgsql (on by default) which adds an isvalid() check constraint to
>> the table. The call to AddGeometryColumn() already adds ndims,
>> geometrytype, and srid checks to the table; why not the equally
>> important isvalid() too?
>> Thanks,
>> Dave Fuhry
> Hi Dave,
> I think I may not have explained myself clearly enough here. When I fixed
> the WKB parser, I didn't add any additional calls into isvalid(). IsValid()
> is a particularly heavyweight function which is why currently this is left
> up to the user to decide whether they wish to use it or not. This is because
> it performs various intersection and repeated point tests which can involve
> lots of time-consuming matrix maths.
> Now the patch I added to the 1.3 series was to make the WKT and WKB parsers
> use the same validation code. The only checks that the WK(T/B) parser makes
> for polygons are i) ensure that polygon rings have a minimum of 3 points and
> ii) ensure that polygon rings are closed (i.e. the first point equals the
> last point). Both of these do seem entirely sane checks to be making.
> I've done a quick check of the SFS specification
> (http://www.opengis.org/docs/99-049.pdf) and the ESRI shapefile
> specification (http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf)
> and both of these mandate that polygon rings *must* be closed. And to be
> honest, I can see that this makes sense - for example, think about how
> should things behave if you try to calculate the area of an open polygon,
> for example.
> So in other words, whoever (or whatever) is generating your shapefiles is
> generating invalid shapefiles according to spec, and I'm not yet convinced
> that this is a good enough reason to start allowing geometries with open
> rings into the database.
> If you really are stuck, I've attached a patch against 1.3 series that will
> turn off the check for WKB, but it will take a lot more convincing in order
> for this (or other relevant fix) to get into SVN.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
