[postgis-devel] Configure step - Mac OsX
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Jul 14 04:51:22 PDT 2008
Courtin Olivier wrote:
> - ./configure step (without any option) end with following error:
> configure: error: the docbook stylesheet directory specified using
> --with-xsldir does not exist
Okay, I've applied another fix for this to SVN trunk. The issue was that
the code couldn't distinguish between a stylesheet being detected from
one of the automatic locations and one specified using the --with-xsldir
option. You should now see an error if a bad directory/filename was
specified for the stylesheet, or a warning if one cannot be detected.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
