[postgis-devel] Docbook ID's and <a name> links
Obe, Regina
robe.dnd at cityofboston.gov
Mon Jul 14 14:45:19 PDT 2008
Okay that's good so we can have meaningful names. So what goes in Chapter 6? I can start moving my changes into chapter 7 and putting in the refentry replacement when you are ready.
So would we just delete whatever we have in chapter 6 once we move it to chapter 7?
Thanks,
Regina
From: postgis-devel-bounces at postgis.refractions.net on behalf of Kevin Neufeld
Sent: Mon 7/14/2008 5:40 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Docbook ID's and <a name> links
Yup, we can.
http://docbook.sourceforge.net/release/xsl/current/doc/html/use.id.as.filename.html
-- Kevin
Kevin Neufeld wrote:
> :) That's a good point. I hadn't considered that. I wonder if there
> is a way to specify the filename used ... I suspect so, but clearly more
> investigation is in order.
> -- Kevin
> Paul Ramsey wrote:
>> Hm, goodish and badish... the direct links are nice, the fact that the
>> names are meaningless is not, particularly since inserting a new
>> function will probably result in the re-numbering of all the other
>> pages...
>> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080714/9372a363/attachment.html>
