[postgis-devel] Docbook ID's and <a name> links
Obe, Regina
robe.dnd at cityofboston.gov
Tue Jul 15 04:10:40 PDT 2008
I just moved over ST_MakeLine. I realized that since we are going with
meaningful names, probably makes sense to have ST_MakeLine variants
appear on the same page. So I made as one entry instead of 2. Does
that look right?
I figure that's the most complicated case we would need to deal with.
I'm also wondering if there is a way in the TOC to pull out the things
that take
Geometry set
as argument.
I've always found it useful to see a listing of all aggregate functions
together, but its also useful to see them in the specific category area.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Tuesday, July 15, 2008 3:20 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Docbook ID's and <a name> links
Ok Regina, I've committed my changes to SVN. I added a new
"reference_new.xml" file to temporarily hold chapter 7. Once the
migration is complete and all the functions have been moved over to this
file using the <refentry> concept, we can drop reference.xml and rename
reference_new.xml to take it's place.
I added a template.xml file simply to show how we can structure each
refentry. Please feel free to make any modifications you see fit to the
template or the new major section headings.
Mark, FYI, it seems the fix you recently made to the doc Makefile does
not work on my FC3 system. It can't seem to parse the file:
Makefile:41: Extraneous text after `else' directive
Makefile:43: *** only one `else' per conditional. Stop.
Dane, I love the new stylesheet. It looks good. I have one suggestion,
though. Perhaps the <programlisting> tags should use a fixed-width font
so code examples look a little better.
Cheers,
Kevin
Obe, Regina wrote:
> Okay that's good so we can have meaningful names. So what goes in
> Chapter 6? I can start moving my changes into chapter 7 and putting
> in the refentry replacement when you are ready.
> So would we just delete whatever we have in chapter 6 once we move it
> to chapter 7?
> Thanks,
> Regina
> *From:* postgis-devel-bounces at postgis.refractions.net on behalf of
> Kevin Neufeld
> *Sent:* Mon 7/14/2008 5:40 PM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] Docbook ID's and <a name> links
> Yup, we can.
http://docbook.sourceforge.net/release/xsl/current/doc/html/use.id.as.fi
lename.html
> -- Kevin
> Kevin Neufeld wrote:
> > :) That's a good point. I hadn't considered that. I wonder if
there
> > is a way to specify the filename used ... I suspect so, but clearly
more
> > investigation is in order.
> > -- Kevin
> > Paul Ramsey wrote:
> >> Hm, goodish and badish... the direct links are nice, the fact that
the
> >> names are meaningless is not, particularly since inserting a new
> >> function will probably result in the re-numbering of all the other
> >> pages...
> >> P.
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
