[postgis-devel] lwpostgis.sql.inc.c?
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 21 11:07:29 PDT 2008
lwpostgis.sql.in.in ? :)
On Mon, Jul 21, 2008 at 9:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Obe, Regina wrote:
>> Why does the trunk lwgeom/lwpostgis.sql.in.c  not called
>> lwpostgis.sql.in
>> Its screwing up the color coding on my editor.  In the branch versions
>> it was named lwpostgis.sql.in
>> I see we did split things out into sqlmm.sql.in etc, but that doesn't
>> seem to explain this choice of naming.
>> Thanks,
>> Regina
> Hi Regina,
> The reason for this is that the PostgreSQL PGXS build system takes an input
> file called <foo>.sql.in, runs it through sed to substitute the path to the
> actual module, and stores the result as <foo>.sql. This file is then copied
> to the correct contrib/ directory as part of "make install".
> In order to allow PostGIS to generate the correct SQL for multiple versions
> of PostgreSQL, we also need to run the output file through the C
> preprocessor beforehand. So the overall process now looks like this:
> i) lwpostgis.sql.in.c is run through the C pre-processor CPP to produce
> lwpostgis.sql.in
> ii) lwpostgis.sql.in is run through sed by the PostgreSQL PGXS build system
> to produce the final lwpostgis.sql
> Note that I used .c to make it obvious that the file is run through CPP
> (plus it uses various macro subsitutions with respect to function types such
> as IMMUTABLE, VOLATILE etc.) rather than being pure SQL. I can't say that
> I've ever run in syntax highlighting problems, but I suspect even an SQL
> syntax highlighter would fail due to the macros involved.
> HTH,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
