[postgis-devel] Function names in PostGIS
Obe, Regina
robe.dnd at cityofboston.gov
Mon Jul 21 18:40:52 PDT 2008
Good points. I guess I'm in the "What OGC functions can I count on in all dbs I work with?" mode that I completely forgot about the ease of not having to remember ST_ from PGIS_ or something like that and the3 beauty of having all the functions ordered together.
Even with that mindset when you compare the strengths and weaknesses of the non-spatial functionality of each of the various different dbs and slight syntactic differences - you end up tackling the same questions slightly differently anyway. So the most I can hope for at this point is Knowledge Transfer which I guess makes the whole ST_ non ST_ argument much less important.
Thanks,
Regina
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Mon 7/21/2008 7:42 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Function names in PostGIS
Originally we were going to have ST_ for standard functions, SE_ for
esri functions (since that's how they are defined in their API) and
SP_ for postgis-only functions. But it seemed like it was imposing a
needless extra memorization step for users: not only do they have to
remember the mnemonic for what the function *does* ("startpoint",
"geometryn", etc) they also have to remember what category it fall
into, so they can prefix it correctly.
In the end we just want with ST_, which at least provided us the name
space uniqueness and general syntactic compatibility with
ESRI/DB2/Informix.
P.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080721/8b5e220f/attachment.html>
