[postgis-devel] Using --with-pgconfig in Makefile.in
Jorgen Austvik - Sun Norway
Jorgen.Austvik at Sun.COM
Fri Jul 25 04:24:39 PDT 2008
with-pgconfig/with-pgsql[1] are not used in PostGIS make files (it will
use pg_config from PATH instead of the pg_config supplied to configure).
Attached is a patch which fixes this issue for me.
In addition topology/Makefile has the same issue, but I didn't find a
Makefile.in there, so I haven't fixed it in the attached patch. Maybe it
is time to create a Makefile.in file in the topology folder too?
[1]
configure says:
--with-pgconfig=FILE specify an alternative pg_config file
while README.postgis says:
You can specify it using the --with-pgsql=/path/to/pg_config flag.
Maybe the readme should be updated?
-J
Jørgen Austvik, Software Engineering - QA
Sun Microsystems Database Group
http://www.austvik.net/
http://blogs.sun.com/austvik/
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080725/9c37a1d8/attachment.bin>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080725/9c37a1d8/attachment.vcf>
