[postgis-devel] Re: [postgis-users] create tables smarter
Obe, Regina
robe.dnd at cityofboston.gov
Mon Jun 9 08:49:45 PDT 2008
Actually I think ST_Geometry_Columns has to be a view rather than a real
table. From what I can gather
Looking at
http://publib.boulder.ibm.com/infocenter/db2luw/v8/index.jsp?topic=/com.
ibm.db2.udb.doc/opt/rsbp4017.htm
and
http://jtc1sc32.org/doc/N1101-1150/32N1107-WD13249-3--spatial.pdf
Looks like the definition includes SRS_Name which we can't very well
expect people to be typing in and we would easily get by joining with
our spatial_ref_sys.
and
Looking at page 476 of this doc (443).
The example implementation looks like below - granted I would say there
code is needlessly ugly (or at least needlessly complicated if we were
to implement similar logic in PostgreSQL I think the joins we would need
to do would be much simpler).
CREATE VIEW ST_GEOMETRY_COLUMNS AS
WITH RECURSIVE TYPES ( TYPE_CATALOG, TYPE_SCHEMA, TYPE_NAME ) AS
( VALUES ( ST_TypeCatalogName, ST_TypeSchemaName, 'ST_GEOMETRY' )
UNION ALL
SELECT h.USER_DEFINED_TYPE_CATALOG, h.USER_DEFINED_TYPE_SCHEMA,
h.USER_DEFINED_TYPE_NAME
FROM INFORMATION_SCHEMA.DIRECT_SUPERTYPES AS h
JOIN
TYPES AS t ON
( h.SUPERTYPE_CATALOG = t.TYPE_CATALOG AND
h.SUPERTYPE_SCHEMA = t.TYPE_SCHEMA AND
h.SUPERTYPE_NAME = t.TYPE_NAME )
( SELECT c.TABLE_CATALOG, c.TABLE_SCHEMA,
c.TABLE_NAME, c.COLUMN_NAME, g.SRS_NAME,
( SELECT s.SRS_ID
FROM ST_DEFINITION_SCHEMA.ST_SPATIAL_REFERENCE_SYSTEMS
AS s
WHERE s.SRS_NAME = g.SRS_NAME
) AS SRS_ID
FROM INFORMATION_SCHEMA.COLUMNS AS c
LEFT OUTER JOIN
ST_DEFINITION_SCHEMA.ST_GEOMETRY_COLUMNS AS g ON
( c.TABLE_CATALOG = g.TABLE_CATALOG AND
c.TABLE_SCHEMA = g.TABLE_SCHEMA AND
c.TABLE_NAME = g.TABLE_NAME AND
c.COLUMN_NAME = g.COLUMN_NAME )
WHERE ( c.UDT_CATALOG, c.UDT_SCHEMA, c.UDT_NAME ) IN
( SELECT TYPE_CATALOG, TYPE_SCHEMA, TYPE_NAME FROM TYPES ) )
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Markus Schaber
Sent: Monday, June 09, 2008 11:04 AM
To: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-devel] Re: [postgis-users] create tables smarter
Hi, Regina,
"Obe, Regina" <robe.dnd at cityofboston.gov> wrote:
> On a side note - I recall reading somewhere that the new name of
> Geometry_columns should be
> ST_Geometry_Columns
It should easily possible to provide the View with both names, for
backwards compatibility.
Regards,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
