[postgis-devel] Split By function
Martin Davis
mbdavis at refractions.net
Mon Jun 23 14:18:42 PDT 2008
This is one function which really needs a code example to show how to
use it. The description is very confusing to people (like me) who are
unfamiliar with SRF's and UDT's (or whatever the set contains -
presumably some kind of object?)
But clearly a very useful function.
Paul Ramsey wrote:
> On Jun 23, 2008, at 1:44 PM, Kevin Neufeld wrote:
>> So, not only does ST_GeometryN not scale well (what is that,
>> quadratic scaling?), but it consumes all memory on my 4GB server.
>> SELECT (ST_Dump(geom)).geom on the other hand is linear and has no
>> problems.
>> Unfortunately, this doesn't solve the ST_PointN equivalent problem.
>> I suggest we add a ST_DumpPoints() method to the TODO list!
> If that's the syntax you want... do you like the .path, .geom thing?
> Perhaps we should do the syntax/naming we like and document that,
> since st_dump appears to be currently unknown(ish).
> P
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
