[postgis-devel] WKT and Wikipedia
Kevin Neufeld
kneufeld at refractions.net
Fri Jun 27 16:42:36 PDT 2008
So, the 1.2 OGC specs require that the WKT of Z, M, and ZM be:
POINT <point text>
POINT Z <point z text>
POINT M <point m text>
POINT ZM <point zm text>
PostGIS has:
POINT <point text> | <point z text>
POINTM <point m text> | <point zm text>
To me, this means PostGIS is not entirely OGC compliant. (ie. PostGIS
can't parse an OGC compliant WKT string)
postgis=# SELECT 'POINT ZM(0 0 0 0)'::geometry;
ERROR: parse error - invalid geometry
Same goes for the textual representation of other geometries.
ie. LINESTRING ZM (...)
Should we add this to the TODO list for 1.4? Or is there a specs gray
area ... that we're compliant enough.
-- Kevin
Martin Davis wrote:
> Actually the latest SFS 1.2 spec does include a spec for 2D measured, 3D
> & 3D measured WKT. See here:
> http://www.opengeospatial.org/standards/sfa
> (This is also referenced on the wiki page)
> Kevin Neufeld wrote:
>> I just came across this page:
>> http://en.wikipedia.org/wiki/Well-known_text
>> I think this page is incorrect, misleading, and contains typos. It is
>> my understanding that the OGC specs on WKT does *not* include 3D and
>> 4D definitions. It is a PostGIS extension to use Z, M, or ZM. Or am I
>> off on this?
>> (http://portal.opengeospatial.org/files/?artifact_id=829) (section
>> 3.2.5.2)
>> I don't have an account to correct this. Does any here have one? Do
>> we care?
>> Should the new PostGIS docs reference such pages, or point to only the
>> OGC specs?
>> -- Kevin
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
