[postgis-devel] non-google bug report, postgres seg fault when comparing geometries
Paul Ramsey
pramsey at cleverelephant.ca
Fri Mar 28 11:34:39 PDT 2008
Thanks, filed. Should be in 1.3.3
On Fri, Mar 28, 2008 at 11:16 AM, Cliff Wright <cliff at snipe444.org> wrote:
> The bug tracker kept asking me to get a google account to report a bug,
> which I do not want, so am using this process instead.
> When using mapnik to display a NOAA nautical chart a postgres server seg faulted while comparing geometries from 2 different tables.
> I did not isolate the exact comparison, however the core dump did indicate
> which line and file caused the problem. looking at the code I see a memory
> free was called apparently pointing at the wrong object. The same free
> is used a couple of lines later pointing at the correct object. The patch
> attached shows the fix I used. I was using version 1.3.1, however see the same
> bug in subversion.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
