API for optimized predicates (was Re: [postgis-devel] 1.3.3)
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 31 10:22:55 PDT 2008
A unique-on-insert ID would be another approach. It would, however,
involve a disk-format change, so we're talking about pretty big
hammers here, regardless of whether we did a hash or a uuid.
Ben, maybe just stick some small timing statements into your current
code... start time, end time, and then do a noop memcmp with start/end
times as well. That way we can compare the memcmp times to the total
times.
P.
On Mon, Mar 31, 2008 at 10:17 AM, Martin Davis <mbdavis at refractions.net> wrote:
> (renaming this thread, since the current one is way overloaded)
> I agree with Paul and Mark - there should be a simple function signature
> for the fast preds. The more complex one can be provided as well, but
> it will need to be VERY well documented, since it's a tricky thing to grok.
> re spatial hash - would you really trust a hash to confirm identity? I
> don't think I would...
> Would another alternative would be to assign a hidden unique ID to each
> geom entered into the DB. This could be a honking big integer, or maybe
> a UUID.
> Paul Ramsey wrote:
> > The problem is that the memcmp hit gets worse in exactly the cases
> > were we expect better and better performance from the prepared
> > algorithm... still, it would be nice to know what that hit is...
> > compared to the original, unprepared time, it will be small, but
> > compared to the prepared-with-id-API implementation... hard to say.
> > Something to resolve before 1.4... It's unfortunate that all the
> > *fast* tests can only falsify identity, not confirm it. I was talking
> > to a fellow who has done a spatial db implementation on a proprietary
> > system, and he was pleased with the idea of a "geographic hash" that
> > he can calculate for each shape and use to test identity. If we were
> > to do something like that, it would have to be optional, like the bbox
> > calculation is currently.
> > P.
> > On Mon, Mar 31, 2008 at 2:51 AM, Mark Cave-Ayland
> > <mark.cave-ayland at siriusit.co.uk> wrote:
> >> On Friday 28 March 2008 23:53:53 Ben Jubb wrote:
> >> > Howdy,
> >> > In my testing, I did see a performance hit when using the memcmp test,
> >> > although it was noticable only in the largest of my test geometries
> >> > (5000 vertices or so).
> >> > The three parameter form seemed like the best way to go because the
> >> > whole point of the prepared version of the functions was to get the best
> >> > possible performance. The cases when the performance matters most is
> >> > with large geoms, and then the cost of doing the memcmp is the highest.
> >> > Using a third argument seemed the simplest way to get the best possible
> >> > performance from the predicates, with a minimal increase in the
> >> > complexity of the interface.
> >> > I agree it would be nice to have a single form for those predicates that
> >> > automatically determines the most efficient manner to do the tests, but
> >> > there didn't seem to be any efficient way to accomplish that.
> >> > b
> >> Hi Ben,
> >> Well I think it really comes down to what exactly is the performance hit and
> >> how did you measure it? Which platform/OS/C library did you use? Obviously
> >> there will be *some* overhead having the extra memcmp() in there but does it
> >> matter? For example, if the overhead is just 1-2s on a 30s query then that
> >> doesn't really matter. Then again, if the overhead is 1s on a 3s query then
> >> that is significant.
> >> Since this is a new feature then I'd be inclined to say that for a first cut
> >> we should keep the standard API, and depending on the reports we get back,
> >> look at improving it later. That seems a lot more preferable to having a
> >> fairly nasty API hack that will catch a lot of people out :(
> >> ATB,
> >> Mark.
> >> Mark Cave-Ayland
> >> Sirius Corporation - The Open Source Experts
> >> http://www.siriusit.co.uk
> >> T: +44 870 608 0063
> >> _______________________________________________
> >> postgis-devel mailing list
> >> postgis-devel at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
