[postgis-devel] 1.3.3
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 31 14:37:14 PDT 2008
This would be trivial if make supported something like 'iflt' or
'ifgte', unfortunately all it supports is ifeq. So I can bust out the
regress tests and do a hamfisted fix that ifeqs GEOS_VERNUM for 22, 30
and 31, or... well, I'm not actually sure what the "or" :)
Hence this:
http://code.google.com/p/postgis/issues/detail?id=16
Do you consider this a blocker?
P
On Mon, Mar 31, 2008 at 10:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> On Monday 31 March 2008 17:38:09 Paul Ramsey wrote:
> > I have a regression failure on 8.3+2.2.3, in the ogc_regress set, but
> > that was because test Covers tests were added to that file, and Covers
> > isn't available in the 2.2.X series. Are you seeing something
> > different? I (bad puppy) just decided to "see no evil" and not bother
> > farting with the regression tests to try and break it out.
> > P.
> Yup, that's what I'm seeing. The functions covers() and coveredby() appear not
> to exist with GEOS 2.2.x.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
