[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com codesite-noreply at google.com
Wed Nov 5 02:38:38 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #1 by mark.cav... at siriusit.co.uk:
Hmmm I can't recreate this here on 64-bit Debian. I see this:
postgis13=# SELECT ST_Dump(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415
1,220227
150505 2,220227 150406 3)'));
  st_dump
(0 rows)
Which platform is this? Maybe the problem only shows on a particular
platform or
32/64 bit architecture?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
