[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com codesite-noreply at google.com
Wed Nov 5 04:52:05 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #3 by robe.... at cityofboston.gov:
Ah slight correction it should return empty path {} and
{CIRCULARSTRING(..)}.
Just retested and get the same crash.
server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Full version info:
         ver_pg_bd
  PostgreSQL 8.2.6 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.2.1
(SUSE Linux)
POSTGIS="1.3.4SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
2008-11-05 12:43:25
Same test on windows XP
"PostgreSQL 8.3.1, compiled by Visual C++ build 1400 POSTGIS="1.3.3"
GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS 2008-04-15
18:49:24"
Ah it completely kills PostgreSQL on windows - have to restart the service
afterward.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
