[postgis-devel] Issue 69 in postgis: ST_Translate crashes when fed circular string
codesite-noreply at google.com codesite-noreply at google.com
Thu Nov 6 09:36:05 PST 2008
Issue 69: ST_Translate crashes when fed circular string
http://code.google.com/p/postgis/issues/detail?id=69
Comment #1 by mark.cav... at siriusit.co.uk:
I suspect this is similar to the ST_Dump() issue: the affine functions are
trying to
recurse on a geometry that that isn't a type that can contain subgeometries.
Unfortunately I've run out of time for this one today...
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
