[postgis-devel] AsGML & AsGeoJson patches
Kevin Neufeld
kneufeld at refractions.net
Tue Nov 11 22:46:44 PST 2008
+1
Obe, Regina wrote:
> +1
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul
> Ramsey
> Sent: Tue 11/11/2008 4:52 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] AsGML & AsGeoJson patches
> PSC folks,
> I think we should add Olivier to the committers. Why? I'm too damned
> lazy to merge in these patches :) (the 1.3 one failed and hand merging
> the regression file is just beyond my will)
> +1 paul
> P.
> On Wed, Nov 5, 2008 at 12:40 AM, Courtin Olivier
> <olivier.courtin at camptocamp.com> wrote:
> > Hi,
> > I've made a patch related to export function, inside it:
> > - AsGML
> > - Curve geometry nice error message
> > - GeometryCollection handle
> > - Code factorization between GML 2.1.2 and 3.1.1
> > - version parameter no more a a global one
> > - use decimal places rather than significants digits
> > (with doc update)
> > - trim trailing zero
> > - unit test file
> > AsGeoJson
> > - add forgotten pfree on subgeometry size process
> > - return geometry type name on error (i.e for curve)
> > Gml3 output was widely test, Gml2 a bit less
> > Patchs provided for 1.3 branches and trunk.
> > Enjoy !
> > FYI, Still on my Todo for theses export functions:
> > - SVG Unit Test
> > - KML decimal places
> > - Trunk doc improve
> > - RFC 5165 compliant (GML, GeoJson, KML also ?)
> > - GML3 Curve handle (low priority)
> > Olivier
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
