[postgis-devel] Issue 31 in postgis: Negative distance buffer
codesite-noreply at google.com
Mon Nov 17 01:15:34 PST 2008
Issue 31: Negative distance buffer
http://code.google.com/p/postgis/issues/detail?id=31
Comment #7 by nicholas.domnic.i:
Hi, just started with postgis, does any one know how do i find the roads
which runs
along a polygon.
There are two tables.
Roads and River i have to find the roads that run along the border of River.
thank you
Nicholas I
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
