[postgis-devel] Issue 71 in postgis: Update section 4.2 of docs to describe manual adding to geometry columns
codesite-noreply at google.com
Fri Nov 21 06:34:50 PST 2008
Updates:
Status: Fixed
Comment #1 on issue 71 by robe.... at cityofboston.gov: Update section 4.2 of
http://code.google.com/p/postgis/issues/detail?id=71
Added a new section for manual registration of tables and views. Also
referenced
this new section in the AddGeometryColumn reference
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
