[postgis-devel] Issue 72 in postgis: ST_Estimated_Extent sometimes returns null if table exists but not in current schema
codesite-noreply at google.com
Mon Nov 24 12:21:44 PST 2008
Comment #5 on issue 72 by ke... at refractions.net: ST_Estimated_Extent
http://code.google.com/p/postgis/issues/detail?id=72
:) Yes, I'm sure he is.
Your function looks great. I haven't tested it, mind you, but I think the
logic here
looks better than using current_schema(). My 2 cents.
I might change ('r','') to ('r') and add a limit 1. (I just cut and pasted
the query
from psql using the -E parameter ... nice feature).
If you wanted to get really fancy, you might even try adding a HINT message
indicating the user try extending the search_path or use the 3 param
version. I'm
not sure how to accomplish this in plpgsql, but Mark figured out how to do
it using
the ereport() function call.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
